Budget (including currency): $820 OR PHP40,000
Country: philippines
Games, programs or workloads that it will be used for: Path of exile, Esports tittles, mmorpgs.
I'm currently looking to upgrade my old set up and I need guidance.
I also need to fit in a 144hz monitor. (budget $820 or php 40,000)
Current setup.
Cpu: i5 6500 (stock cooler)
Motherboard: Msi B150m bazooka
Gpu: Gtx 1060 3gb
Ram: corsair vengeance 8x2 2666 ddr4
Power supply: Seasonic m12ii 520watts
Storage: 120gb ssd (for os) and a two 1tb hhd
I can probably reuse my ram (if 2666mhz still okay this day), drives and case depends on the budget.
https://linustechtips.com/topic/1349232-looking-for-help-upgrading/
1 minute ago, Omar.B said:
No need to change the ram https://pcpartpicker.com/list/44JLmk you still have a 100$ to spend and you can sell your old CPU ,MB and PSU
I'm also looking to change my gpu?
maybe I could reuse my old case and go stock cooler? or probably get a cheaper board.
I recommend you save your GPU now because finding one with good price is so hard , For the case you can still take a cheaper one like the 275R or something with mesh front panel and buy a 5 kit of fans from arctic for 45$  https://pcpartpicker.com/product/LmCFf7/arctic-p12-pst-563-cfm-120-mm-fans-5-pack-acfan00137a or you can stay with the old one
For MB don't go with cheaper one because you cant find one as good as this one with this price, the stock cooler is meh
I see, thank you. I'll keep those in mind.
  • 2 weeks later...
