Just now, 8tg said:
Clean it, repaste it.
Thats also not particularly hot, depending on the cooler anyway. Those temps are well within what it can handle.
its  been hot the pest 3 days since there is  heat wave so i dont think its the paste or it being not clean but thank you
https://linustechtips.com/topic/1349102-cpu-hot/#findComment-14816377
The heat wave is the problem. Higher ambient temps mean higher CPU temps, same as lower ambient temps mean lower CPU temps.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1349102-cpu-hot/#findComment-14816390
