Hey bros, I am Dutch. I am living in Singapore(a place where network doesn't give any issue). I have a custom gaming pc with i5-9400f and gtx 1070 with 16gb of ram.
I have been experiencing lag when i am playing csgo and valorant. I am one wall away from the router. I tried moving the whole set up to the dinning room but it didn't help either. i got the same speed and latency. i even reset all my ingames settings to default but it didn't help at all.
Something u all should know is that i am using a 1300mbps TP-link Archure T4u something like that type of wifi usb dongle.
Thanks for reading, means a lot.
https://linustechtips.com/topic/1349015-urgent-network-issue-please-help-quick/
Try over ethernet, if the issue persists then it's likely your ISP and not your equipment.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
5 minutes ago, Daksh Narang said:
Dude thanks for the reply! Like I said i am one wall away, which is very far from the router  and i can't bring the cable over here.
You can run an ethernet cable 100 meters... There is a difference between not being able to and not wanting to.
Also, I see no urgency here. What, are you gonna get expelled from school / lose a job / suffer an injury if you don't resolve this problem quickly?
thanks for replying. The thing is i have experienced this issue for too long and now i am tired of it so want to get over it asap. Yes you can runt he cable 100 meters but the thing is that i am my family are staying in a rented place so running a cable along the walls is not an option as i can't be hammering things and running on the floor can be disturbing so yea...
thanks again
thanks again
I never said to do so permanently. I said you should do it for 30 mins to test whether the issue occurs over ethernet.
SPECS:
