Budget (including currency): 900
Country: us
Games, programs or workloads that it will be used for: apex legends CSGO
https://pcpartpicker.com/list/kKZPp2
https://linustechtips.com/topic/1348876-first-build/
3700X has no onboard graphics, and you don't have any type of GPU or display adapter on the list, so as it is this PC isn't even usable.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1348876-first-build/#findComment-14814797
Your case has a front USB-C port but your motherboard has no header for it, so you'd have to use adapters that would end up making some or all of the front USB work slower than its intended speed.
I would tend to think you'd be better off to get a B550 board, and a 5600X, which would be at an advantage over the 3700X in games like CS:GO with its improved IPC and clock speeds. There's just no reason to go B450 in 2021 unless you're on a really tight budget.
https://linustechtips.com/topic/1348876-first-build/#findComment-14814814
