water cooling ram
I know most people agree that water cooling your ram isn't necessary but i want to do it anyway if i can without sacrificing ram performance. I want to use the xspc memory waterblock; is there any other ram besides corsair dominators that i can use with it without voiding the warranty? Blue color would be nice if found thanks.
https://linustechtips.com/topic/134850-water-cooling-ram/
The barbs on the kit of memory is 1/4" ID if I remember correctly.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/134850-water-cooling-ram/#findComment-1793790
