F@H low PPD.
Solved by Whaler_99,
Depending on the WU the point numbers can vary quite a bit on both CPU and GPU WU's - so comparing one to another is difficult, unless also looking at the WU and project number and such. Some WU's don't push the GPU very hard and as you have one of the oldest models still somewhat supported, this may explain it. Watch for a couple of WU's and see how it goes.
