Budget (including currency): hopefully below 1750, but max is 2000
Country: USA
Games, programs or workloads that it will be used for: Mainly csgo, valorant, minecraft, and running a program that we use for work to connect to a desktop at out office
https://pcpartpicker.com/list/gBL4LP i have this part list picked out but im not sure if its the best, i for sure want a corsair iCue case of some sort and i already have the 1tb ssd on that list along with a mouse and keyboard, the only other peripheral i would need besides a monitor would be a mouse pad but that is not a huge priority. If anyone could help me out with this or give me some advice i would greatly appreciate it.
Thanks all, Kris
https://linustechtips.com/topic/1347102-my-first-build/
You could do much better in specs for the price, although anything above this would be overkill for your use case IMO.
Here's what I'd recommend:
https://pcpartpicker.com/list/yDzkQD
CPU: AMD Ryzen 5 5600X   ($299.00 @ B&H)
CPU Cooler: Cooler Master Hyper 212 Black Edition   ($42.00 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS   ($156.00 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) 3600Mhz CL16   ($91.99 @ Newegg)
Video Card: NVIDIA GeForce RTX 3070   ($499.99)
Case: Phanteks Eclipse P360A  ($79.99 @ Newegg)
Power Supply: EVGA G5 650 W 80+ Gold  ($75.98 @ Amazon)
Case Fans: 2x Phanteks PH-F120SK   ($9.99 each @ Newegg)
Monitor: AOC 24G2 23.8" 1920x1080 144Hz   ($232.00 @ Amazon)
Custom: Mousepad   ($30.99)
Total: $1527.92
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14800975
2 minutes ago, mahmoud2559 said:
you have such a good stuff,
but if you want something better, be patient until late 2022 and you can afford the rtx2060 for the same price of gtx1660
yeah, thats what i have been hearing alot from my buddies aswell, i think that is what i will do since i do still have my playstation to play on so i will probably end up waiting on it, thanks for your help.
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14800982
2060 is not that good, and the 3060 is cheaper (in terms of MSRP). By then the 4060 will be released, so this makes ZERO sense.
He could also afford a 3080 (or by 2022, a 4080) in that budget, that doesn't mean he should get either.
A 2060/3060 is better suited for a $1000 build, not a $1500-$1750 build.
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14800995
so then what specifically would you recommend i use? obv once the prices drop
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801008
For your budget, a 3070 makes the most sense right now.
Next year when (hopefully) the prices drop, probably the new equivalent to that would make the most sense (likely a 4070).
Are you just waiting for the GPU? Or are you waiting to build the full system?
If so, everyone will be on a new socket and running DDR5 in 2022, so part of my list is irrelevant because the recommendations will be different by then.
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801016
im not sure, i really want to build a pc soon but the only non peripheral item i have right now is my ssd, what i thought about doing is just getting a lower quality gpu for right now and running that for awhile until prices drop and i can ghet my hands on another one.
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801021
13 minutes ago, Krisonis said:
what i thought about doing is just getting a lower quality gpu for right now and running that for awhile until prices drop and i can get my hands on another one.
That's what everyone else has been doing already, so I'd recommend doing the same 😁
I've been using an old R9 390X while waiting, it gets the job done for 1080p/Medium settings.
If you can get your hands on something like a GTX 1060 for anything less than $200, that'd be great to hold you over until then.
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801034
Alright, i will look into it thanks for the help.
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801052
thx man I appreciate it
you are amazing and so helpful
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14801985
No problem guys, you are both very welcome! 😇
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1347102-my-first-build/#findComment-14802022
