Hello everyone, new member here and I am facing a problem with my new PC. Yesterday I built a new PC for my first time and it was working fine for the first couple minutes of its life until it experienced a blue screen of death. The bluescreen said it was a memory management issue and what failed was "WdFilter.sys". After the PC reset itself it got stuck in a constant boot loop of blue screens, I couldn't even get into windows for roughly 3-5minutes. Each blue screen was displaying different failures everytime. Really looking for some help, thanks everyone!
MOTHERBOARD: MSI B550 GAMING EDGE WIFI
CPU: AMD RYZEN 7 3700X
GPU: NVIDIA GTX 950 SSC (old card until things become more reasonable)
MEMORY: 2X8GB CORSAIR VENGEANCE LPX 3200MHZ
SSD: SABRENT 512GB ROCKET M.2
PSU: CORSAIR 750W 80+BRONZE
https://linustechtips.com/topic/1347073-new-pc-build-problem/
I bet you just had a bad windows install
Shut down and try a windows reinstallation. Do you have access to another computer or laptop right now?
If so go here: https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d
And follow the directions.
https://linustechtips.com/topic/1347073-new-pc-build-problem/#findComment-14800759
I can do some swapping around and get my graphics card back into my old PC, do you know any reason a Windows install could go bad?
https://linustechtips.com/topic/1347073-new-pc-build-problem/#findComment-14800781
Million reasons - sometimes it just happens that's why I would download a fresh image on a usb for install. Just do a clean slate. That's the most likely reason. Do you have a friend who would just let you download onto a USB? Swapping around your graphics card just to download a windows installer sounds like a bad time :).
https://linustechtips.com/topic/1347073-new-pc-build-problem/#findComment-14800830
