Shift key getting stuck
Solved by Pixelfie,
38 minutes ago, James Evens said:1. Clean it
2. There isn't much todo. Costar and membrane.
I was actually about to do that, but just thought it would be a good opportunity to look into this issue. I also noticed a little plastic thing was about to break off, just glued it back together. Hope that's gonna help.
Edit: that seems to have fixed it
