Okay, so ever since early February my pc has been having this problem where whenever I try to turn it off the cpu error light comes on and the cpu fan speed increases. I’ve just been turning it off from the psu for now, but I was told if I keep doing that I could damage the psu. So far to fix it I have tried all of the following.
  • reseated the ram
  • made sure it was set to turn off in the windows power settings
  • uninstalled the RGB software
  • updated the bios
  • shut it off using the power button in windows
  • shut it off using a screwdriver on the motherboard
  • checking for any scratches on the motherboard
  • buying a new cpu cooler (also thank you Linus for the cooler recommendation)
I’ve done all of this and nothing has worked. I’ve tried asking people on Reddit (both tech support and pcmr) and I still cannot figure out what is wrong with my pc. Has anyone had a similar problem and/or has a solution? I don’t know if this will help, but here are my specs.
  • amd Ryzen 5 2600 cpu
  • Amd rx 580 gpu
  • MSI b450 tomahawk max MoBo
  • tforce delta rgb 8gb ram
  • thermaltake 500w 80+ psu
  • crucial p1 500gb m.2 ssd
  • samsung 870 2TB sata ssd
  • seagate barracuda 2TB ssd
https://linustechtips.com/topic/1346123-pc-will-not-complete-shutdown/
1 hour ago, Red_Fox_1293 said:
Okay, by the looks of this post it’s just an issue with the motherboard. I think I’ll just get an x570 since those work with my current cpu and have newer components. Thanks for the help
9 minutes ago, BeanTeen said:
Currently I just use the switch on the psu
but why cant you shut it down in your operating system?
i9-10980xe 4.5ghz all cores | EVGA RTX 2080 XC ultra clocked at 1965mhz and memory clocked at 8417mhz | 128gb 3200mhz |
