Alright, so about 3 weeks ago or something like that I noticed that the bluetooth quick toggle in the quick settings had disappeared. I checked my bluetooth settings and noticed that there was no option to turn bluetooth on or off. I dont use bluetooth that much so I didnt bother trying to fix it, hoping that a couple restarts or windows update would fix the issue. I have more recently noticed that my wifi speeds have not been the greatest on my desktop, which sits pretty close to the router and is using the 5ghz band of which it is the only device on it. Today I opened device manager and saw a couple things. First, under the bluetooth adapter tab thing, it was giving me error 45 and saying that the adapter was not connected. The second thing that I noticed was that it appeared that several of the wifi adapters were also not connected giving the same error code. I uninstalled the bluetooth adapter from device manager, and now whenever I do a check for hardware changes scan, its not showing up again. I have downloaded the latest drivers for the wifi adapter and am still having the same issue. The pictures should show a little better what I mean. I have an asus tuf b series motherboard with the bundled realtek m.2 to pcie wifi and bluetooth combo card. Any help would be wonderful.
https://linustechtips.com/topic/1346105-bluetooth-gone-from-settings/
