6 minutes ago, One-Custard-4811 said:
a 5800x when i can get hold of one
Should be about able to handle it. The 5800x runs very hot for what it is compared to the other ryzen chips and this cooler would be the bare minimum. I would honestly opt for the sycthe to have some more headroom.
https://linustechtips.com/topic/1345940-cpu-cooler/#findComment-14794715
ok. thanks for your help. ill check local hardware shops if they have any in stock
https://linustechtips.com/topic/1345940-cpu-cooler/#findComment-14794858
