I recently build myself a new PC and I use it primarily for 3D rendering and I am contemplating whether I should upgrade my CPU cooler (nothing is overclocked).
Using the MB monitoring tool I get three CPU temperature and I do not know what temperature I should use.
This is what I have currently with my CPU under full load with the stock CPU cooler.
My current PC build is:
MB: ASUS TUF X570 plus
CPU: Ryzen9 3900 TDP65W  (not 3900x)
Ram: 64GB
Graphics card: EVGA 3060 XC
PSU: 750W
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/
install hwinfo64 to get precise reading, and find CPU (tcl/tdie), in that screenshot probably CPU package.
That's the hottest spot inside the core.
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/#findComment-14791690
The temperatures according to hwinfo64.
The max temperature and clock speeds do not change when under full load even with warmer ambient temperatures
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/#findComment-14791705
At full load? it's normal to have 80c far below 95c threshold. Don't worry.
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/#findComment-14791715
The stock cooler for 3900 is already good.
Aftermarket is definitely better but, in your case it's not that urgent.
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/#findComment-14791741
19 minutes ago, Moonzy said:
Seems like expected temps, nothing to worry about
Though, what load is it under when you took the temps? All core 100%?
Yes it was all core 100%, the temps stay around that point the whole time it might go to 81 for a min or two but drops down to 80 again
https://linustechtips.com/topic/1345846-ryzen9-3900-cpu-temps/#findComment-14791829
