I have a budget of 800 euro at the moment.
The space for the subwoofer is 2.8m, but the speakers have to fit next to them without making my sound stage really small..
POLK HTS-12 400 euro 43,50 cm width <- So could buy 2
SVS PB-1000 PRO 700 euro: 38 cm width <- Can only buy 1
SVS SB-1000 PRO 600 euro: 34 cm width <- Can only buy 1, but would have budget to buy another one in a few months.
Other recommendations?
I will use the subwoofer for watching movies, anime for like 90% of the time.
Have not experienced lower than 27hz before, so I don't know if the extra money is worth for the low HZ.
Which subwoofer(s) would be good for me?
Everything Digital
https://linustechtips.com/topic/1345525-subwoofer-recommendations/
I am not understanding your layout.  How large is your place in total m^2? One wall is 3.8m and one is 3.5? Think your measurements are off.
I would greatly suggest a sub  that can go to 20Hz or lower if you can.  Ultralow frequencies make the movie, IMO.
I'd shoot for dual SVS even if you have to go smaller, unless the freq. resp. is such that you lose out on ultralows.  Otherwise, i am a big fan of SVS.
If you have a small place, may want to get a house before you invest in that.  My neighbors hated my Mirage sub.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Yeah Total is 28 m^2
I live in a brick-made shed, which was not correctly build. So the wall distances deviate. There is also a small storage room on the door side as you can see in the picture. For example: If my speakers are aligned then the left one is further from the wall then the right one, because of this deviation..
I live around 20 meters from any neighbours so they are not an issue.
But for the ultra low I should go for the PB-1000 pro right? Would that ruin the experience compared to 2 sb's in terms of feeling the bass or?
FORGOT TO MENTION THAT BOTH SVS'S WILL BE FROM THE 1000 PRO LINE!
What I really want is to feel the movie, so that's why I am upgrading from a 150 euro Onkyo sub(27hz) to something beyond.
Everything Digital
2 minutes ago, Jonathan=PC said:
Yeah
I live in a brick-made shed, which was not correctly build. So the wall distances deviate. For example: If my speakers are aligned then the left one is further from the wall then the right one, because of this deviation..
Right, the PB 1000 is a greatsub.  With the right placement it'll be fine vs 2x subs.  With such a small place, 2x would be difficult to work with I think.
OnePlus Ecosystem:
3D Printing:
Thanks! I heared a lot about the place being very booming and too overwhelming for the ears. Or is that something an audiophile would hear, but normal people wouldn't?
Then I would buy the PB-1000 PRO
Everything Digital
You'll most likely feel the boom and ear issue in the small space.  I advocate some baffles or other sound materials around your place to offset.  It really is how the room is built, dimensions, placement, how the wave develops along surfaces/walls, deadening materials (sofas, beds, baffles on walls).
You're limited, but using the settings on the sub, receiver, and playing with placement and furniture... I think you can come out with a good experience with it.
OnePlus Ecosystem:
3D Printing:
Thank you very much!
Got a few 25x25x3cm acoastic foam coming in the near future or do those only help with the high frequency's?
My bed is against my desk in the corner and almost the entire room is blocked off by my couch, would that help with dampening?
Everything Digital
Well it'll depend on the foam, if it's that cheap stuff with the... whatever this is (Amazon.com: 12 Pack Acoustic Panels 1 X 12 X 12 Inches - Acoustic Foam - Studio Foam Wedges - High Density Panels - Soundproof Wedges - Charcoal: Musical Instruments), I mean you'll need quite a few to help at all, they're not very effective. Thicker and denser paneling will help more with acoustics. It should help somewhat with the bass, but yes, paneling is most effective for higher frequencies. As for your other question, yes it likely will when compared to an empty room or a room filled with say, metal and concrete objects, however I don't think we can tell you to what extent it will help.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
Was watching a pb-1000 pro review and saw this.
Now i am beginning to doubt if it's a good idea to buy it..
Everything Digital
It could be that the guy has an agenda to push (bought multiple subs and wants to justify it), maybe he's just a sensitive listener, maybe he has a special situation or he's used to far better/more expensive subs, maybe he's just bs'ing you, who knows. I'd say it's fine, you're probably going to be fine with a second sub, And remember what this guy is saying applies should apply to most or all subwoofers in general, and almost certainly the subs you can afford. The dude is a random on the interenet, what he says (or actually, everything anybody says about audio) shouldn't be taken as a fact. How we experience audio is subjective, so only real way to tell if they're correct to you is if... you try it out yourself.
You can totally go out somewhere that sells subs or speakers in general and try out that theory for yourself. You might not even need to try out two subs, or a pb series sub, just try out a single sub and see how you like it.
Oh, also no matter what foam you have, you usually want always think about placement ahead of time. When I'm thinking about foam placement, here's what I prioritize:
If you have anything that's rear ported, you'll want to prioritize putting foam behind those speakers. After that, I'd probably place acoustic foam behind any speakers or subs you have/plan to buy, and I'd put the rest most likely nearish to corners, if there's any left over, I suppose you might want to just place the symmetrically (for aesthetics) in an area that would help with the acoustics- Near to the speakers, perhaps just next to your listening position, whatever.
I just saw a "shootout" of a whole bunch of subs and the guy tested the frequency ranges with a calibrated mic in an open field. The SVS is definitely something to go for. Very flat response, a lot of power, and good extension into the low range.
Here's the video with some budget ones, he later did the SVS on his site. They went down to 12.5hz before failing the CEA-A standard.
https://www.erinsaudiocorner.com/loudspeakers/cea-2010_subwoofer_testing/
#Muricaparrotgang
You don't have a large space so it shouldn't be hard to pressurize the space.
2 subs are almost always better than one.
1/3rd along the wall from the listening position is preferred but since your desk is there I think the red boxes where I show are best.
Point the drivers towards each other.
