So, built a complete new PC, but am having problems getting my 6900XT card to run correctly, I have low utilisation and low framerates.. My card is the AMD reference design, and I have also tried the Powercolor reference with the same results.
Here is a quick video I did of the issue:
My main specs are:
Ryzen 5600X
ASROCK X570 Taichi "Razer Edition"
32GB G.Skill Trident Z Neo 3600 (F4-3600C18D)
AMD reference RX6900xt
Corsair RM850 PSU, GPU 8 pin NOT daisy chained, purchased 2 x separate corsair braided cables with single 8 pins on each.
My monitor is a Razer Raptor 27", hooked up via USB C
My Userbenchmark results:
UserBenchmarks: Game 182%, Desk 102%, Work 171%
CPU: AMD Ryzen 5 5600X - 97.8%
GPU: AMD RX 6900-XT - 188.4%
SSD: Samsung 960 Evo NVMe PCIe M.2 250GB - 239.3%
SSD: SanDisk Ultra 3D 2TB - 109.9%
HDD: Seagate ST2000LM015-2E8174 2TB - 44.5%
RAM: G.SKILL F4 DDR4 3600 C18 4x8GB - 103.1%
MBD: Asrock X570 Taichi Razer Edition
The BIOS on my X570 is the latest, I'm using the latest (just released) AMD chipset drivers and latest GPU driver. My FCLK is set to 1800Mhz to match my RAM @ 3600 (all set manually).
Any help would be much apprecited!
https://linustechtips.com/topic/1345245-rx-6900xt-low-gpu-utilisation/
what resolution you playing at?
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
is that with all setting to the right?
in 1440 with high end gpu like that you'll likely run into bottleneck on your cpu
but thats kinda unlikely since your cpu also almost doing nothing
can you jump into "heavy" scene like intense battle or something and see the result
