Okay so,
Specs:
RTX2060
AMD Ryzen 5 2600X
16GB 3200Mhz
I've come so far, I'm so depressed that I've created an account and asking directly.
So with the singleplayer is everything perfect, highest settings 60 fps capped with V-sync, same with the lowest settings, perfect.
Well going into GTA Online, no matter what setting I use, when there are more than 10 people in the lobby I have mega drops to under 30 fps, or basically staying 40fps the whole time, I've tried anything to improve fps, I've changed command lines in the directory. Setting the game settings to maximum performance, so forcing yo use more gpu, which looked like it worked for a while, but after less than a week, it stopped working. I really tried everything on the internet. Also thought it may be a general gpu problem. Do you have any other solutions?
https://linustechtips.com/topic/1344932-general-gta-online-problems/
This is normal Online performance.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
