hello everyone, i will be straightforward with my problem.
so my problem happen time to time and i don't know why, and i don't know how to explain it but i have a picture. it will be easier to understand.
as you see the discoloration or whatever it's called. its just suddenly happen when i open my pc.
p.s(i never turn my pc off).
how can i fix it ?
https://linustechtips.com/topic/1343935-graphics-card-problem/
Ouch that's a lot of artifacts. Does it just happen on Twitter, or does it happen with all the programs that you run? What GPU is it? What are your system specs?
RYZEN 7 3700X / MSI X570S TOMAHAWK MAX WIFI / ZOTAC 3070 TWIN EDGE OC / CORSAIR VENGEANCE RGB PRO 32GB @ 3200 / SAMSUNG 980 PRO M.2 / WD BLACK SN850 M.2 / GIGABYTE P750GM 80+ GOLD / MSI MAG FORGE 100R / MSI MAG CORELIQUID 240R
https://linustechtips.com/topic/1343935-graphics-card-problem/#findComment-14776930
it happen with all the programs.
GPU:
EVGA GeForce RTX 2060 SC Ultra GAMING, 06G-P4-2067-KR, 6GB GDDR6, Dual HDB Fans
CPU:
Intel Core i7-8700K Desktop Processor 6 Cores up to 4.7GHz Turbo Unlocked LGA1151 300 Series 95W
RAM:
G.SKILL Sniper X Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel X299 / Z370 / Z270 / Z170 Platform Desktop Memory Model F4-3000C16D-16GSXFB
motherbaord:
MSI PRO Series Intel 8th Gen LGA 1151 M.2 D-Sub DVI DP USB 3.0 Gigabit LAN CFX ATX Motherboard (Z370-A PRO)
https://linustechtips.com/topic/1343935-graphics-card-problem/#findComment-14777349
Artifacts usually indicate an issue with your GPU, heat could be an issue in your case causing the card to overheat. Have you tried re-installing the drivers? We could start with that.Is your card overclocked?
https://linustechtips.com/topic/1343935-graphics-card-problem/#findComment-14778790
