Budget (including currency): +- 2300$ CAD (before taxes)
Country: Canada
Games, programs or workloads that it will be used for: Streaming and gaming
I'm upgrading from a 2013 computer. I need to be able to use multiple screens and a flawless stream in high def.
Note: the budget is without a video card, as I am postponing the purchase for a later date. My goal is a Geforce 3080 RTX
Here is the build I thought:
AMD Ryzen 9 5900X 12-Core 3.7 GHz Socket AM4 105W 100-100000061WOF Desktop Processor
Corsair 4000D Airflow CC-9011200-WW Black Steel / Plastic / Tempered Glass ATX Mid Tower Computer Case
ASUS TUF Gaming X570-PRO (WiFi 6) AMD AM4 (3rd Gen Ryzen ATX Gaming Motherboard (PCIe 4.0, 2.5Gb LAN, BIOS Flashback, HDMI, USB 3.2 Gen 2, Addressable Gen 2 RGB Header and Aura Sync)
Seasonic FOCUS GM-750, 750W 80+ Gold, Semi-Modular, Fits All ATX Systems, Fan Control in Silent and Cooling Mode, 7 Year Warranty, Perfect Power Supply for Gaming and Various Application, SSR-750FM
Crucial MX500 2TB 3D NAND SATA 2.5 Inch Internal SSD, up to 560 MB/s - CT2000MX500SSD1
Crucial P5 1TB 3D NAND NVMe Internal SSD, up to 3400 MB/s - CT1000P5SSD8
G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16D-32GVK
Things I'm looking for on this forum: Suggestion for a cooling system, a thorough check to see if the casing I chose is good, parts suggestions and a mobo that doesn't need flashing (I prefer asus). I also would like an input on RAM.
I'd like to buy parts from Canada Computers, and all parts from the same vendor as much as possible. I know some parts may be overkill, but I like to keep my machines on a long term basis to reduce my footprint.
Any comments on this is also appreciated.
Thanks in advance
https://linustechtips.com/topic/1343179-need-help-and-recommandations/
Here's a thorough look on the 4000D:
For the ram you could go with 3600Mhz, zen3 CPUs can benefit from faster ram
It's very hard to tell whether a mobo model will come with the proper bios. At least I could never find thoroughly accurate info on that. But if the one you pick has bios flashback it's easy peazy, you don't need anything else plugged into it than a usb stick with the new bios and the PSU. Then you press the flashback button and you're all set.
For the cooling the Arctic freezer II 280 is a great AIO from what I heard, and it would fit nicely in the case you picked.
