You probably need drivers. What model is your motherboard?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
Just now, Justin57 said:
h61m-p20
You can download your network drivers from https://download.msi.com/dvr_exe/mb/realtek_pcielan_w10.zip.
Desktop
Homelab
1 minute ago, Justin57 said:
Is there alternative link with downlead button? it says not found @PorkishPig
It's available under the LAN Drivers drop down at https://us.msi.com/Motherboard/support/H61M-P20-G3#down-driver&Win10 64.
Desktop
Homelab
2 minutes ago, Justin57 said:
after that it was same as in the last photo @PorkishPig
Is your Ethernet Controller visible in Device Manager (Win+R, enter devmgmt.msc in Run) under Other Devices?
Desktop
Homelab
there is no "Other Devices" in Device manager 😕
Did you purchase this motherboard used? It's possible that the previous owner may have disabled the Ethernet Controller in the BIOS. Try entering your BIOS and using Restore Defaults under Save & Exit.
Desktop
Homelab
How do I enter BIOS?
4 minutes ago, Justin57 said:
after some digging found this in "Show hidden devices"
Since the device is greyed out, this just means that the device was previously connected but is no longer present.
Spam the Delete/Del key when booting.
Desktop
Homelab
10 hours ago, Justin57 said:
I can't enter BIOS
You need to spam Delete immediately after pressing the power button. If you see Windows loading, you can no longer enter the BIOS. Note that this is the Delete key, not backspace.
Ethernet was working for first 2-3h of using PC, and then when trying to change it to wifi and after watching a video how to change it, now there is no ethernet.
Your motherboard does not have wireless capabilities. Do you remember what changes you made to attempt to enable Wi-Fi?
If you view the properties of Realtek PCIe Fe Family Controller, does it report "Currently, this hardware device is not connected to the computer. (Code 45)"? Are there any LED indicators blinking on your Ethernet port?
Desktop
Homelab
