Quick Temps question
Go to solution Solved by ramava,
A quick search on reddit showed that TMPIN4 in particular may be showing odd readings depending on your board. Have you look in HWINFO64? One you find all the relevant sensors, it's more descriptive on what the sensors are.
Really depends. If thats under full load, then its normal for most situations. But as we do not know what CPU, what cooler, what case, what room temp or any other variable which will have effect, its impossible to say.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1342571-quick-temps-question/#findComment-14767773
