Hi all, I don 't know if thats the right subtopic, so if it's wrong pls move it where it belongs 馃檪聽Just posting again after a 8聽year hiatus, so not quite sure where to put it 馃槃
I bought a quest 2 some months ago and played some BeatSaber back then, but didn't play for the past couple of weeks..Yesterday I started again, to play some Ragnarock with my flatmate, and my Quest does behave strange. In the Oculus Software it's shown as connected, but the connection test doesn't work (1 out of 10 maybe). Same with SteamVR, mostly it doesn't find my Quest.
I already reinstalled the Oculus Software aswell as SteamVR, I reinstalled all the drivers for the Quest, I factory reset the Quest, tried every USB port, bought an extrta pcie USB 3.0 expansion card...
I did not change anything hardware related to the last time I played, and back then it worked flawlessly, just plugging in, starting SteamVR and playing Beatsaber. I know that my hardware is outdated af, but she still works fine, and the fact that it worked so well just 2 months ago makes me think it's either software thats bugged, or my PC does wierd things software related.
Anyway, thanks for all the help. Maybe someone has a solution, cause I tested anything and can't find a conclusion...
https://linustechtips.com/topic/1342100-weird-oculus-quest-2-problems/
