Hi. I just built my first pc. It has a ryzen 5 3600 and a 1060 6GB card. But it wont post. I am using a gigabyte aorus elite which i bought used. Out of the box the motherboard supports the 2000 generation of processors. But from what i have seen i should be able to get into bios without a bios update. The PC is turning on fine and all the fans spin (gpu and cpu cooler too). Is the bios version the reason or could it be something else?
https://linustechtips.com/topic/1341798-pc-wont-post/
Does your board have Ez debug lights? If so what do they read?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1341798-pc-wont-post/#findComment-14760970
Just now, carsdonotsuck said:
What is an EZ debug light and where can i find it
what exact model of the arouris elite do you have?
b450 b550?
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1341798-pc-wont-post/#findComment-14760998
On this diagram #21 corresponds to the Lights on the board. This is for the b450 V.1 of the board.
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1341798-pc-wont-post/#findComment-14761009
It stays constantly red
On what light there should be 4
Cpu/Dram/VGA/boot
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1341798-pc-wont-post/#findComment-14761036
