did you try using the HDMI?
Did you install drivers?
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
Just now, JustACube said:
i've tried using the hdmi and i cant install any drivers because im not getting any output
weird.
Ok what I'm wondering is did it actually work with the hdmi?
My PC
2 minutes ago, JustACube said:
i dont know if its a graphics card problem
It might be.
To check this I want your to turn off the computer many times Until windows gets you into recovery mode.
At this point what we want is enter into safe mode to do some software troubleshooting steps before hardware troubleshooting and then we consider something a severe problem
My PC
3 minutes ago, GorujoCY said:
It might be.
theres no output at all
does the gpu fan spin or any indication that it's alive?
My PC
1 minute ago, JustACube said:
might be that windows doesnt recognize the gpu
fake gpu?
where did you buy the GTX 1060?
My PC
3 minutes ago, JustACube said:
it doesnt spin
That means it's a dead gpu. Where was the gpu bought, Ebay? Craiglist?
if any of these contact the seller, well see if he accepts returns, Id your money back guarantee isn't expired and the seller doesn't accept refunds and returns on ebay, Contact Ebay to get your money back.
Edited by GorujoCY
My PC
no the gpu is good i had windows a long time ago then switched to linux and now i wanted to install windows again but this is happening
weird. If it works on Linux then it should work on windows if the GTX 1060 is the real deal.
Are you sure you can't get through windows safe mode or is it because you have grub bootloader on?
My PC
theres no output and this started happening after windows restarted when installing theres completely no output and i dont know whatgrub bootloader is
Try to boot linux again to see if it still works there?
F@H
GPD Win 2
Do you even see the BIOS or nothing at all?
It does seem like it just randomly failed...
F@H
GPD Win 2
then yeah you need to get into safe mode and DDU the Graphics Drivers.
essentially one way you can do it without needing to go into Windows.
To do that power off and on your computer, when the computer is on, Always wait for Windows to start loading, Right away start to power it off by holding the power button, repeat that 3 times Until you see the message along the lines of "Diagnosing your PC" assuming that your active bootloader is currently windows and that's a good thing. Then boot to safe mode with Networking, Let me know when you get there.
Edit: if the gpu is dead, There's no point in doing that.
My PC
ywah I'm confused whenever it works or randomly stopped working out of a sudden, If the gpu fans don't work or no indication of power on then it should be a dead gpu
My PC
Then take it out, reseat, check the power connection etc, and clear CMOS for good measure...
F@H
GPD Win 2
i dont see anything at all i think the gpu isnt even running
then it's a failed gpu.
again where was this gpu bought?
edit: Good step above for good measure before this
Edited by GorujoCY
My PC
i think something like this happened when i was installing windows the first time the gpu needed a driver because it wasnt getting recognized by windows
