Idle SSD, HDD and CPU temp questions
Solved by AdamBGames,
27 minutes ago, SomeRandomNerd said:Hi, new builder here! Is it normal to have the CPU (5800x) at 41 degrees Celsius when idle? And my two ssds (980 PRO and MP600) are at 49 degrees idle. Is that normal? Thanks!
As long as the M.2s have heatsinks which the MP600 has one, you should be fine. 41C at idle is normal for a CPU.
achiboyke ·
Posted in Troubleshooting1 -
testcy ·
Posted in CPUs, Motherboards, and Memory5 -
7
Goodmen9008 ·
Posted in Graphics Cards6 -
3
1
Asus Prime X670-P + Hyper M.2 - 4 Crucial NVMe - Showing 4 Separate Drives & Not Logical Volume RAID
JasmeowTheCat ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
