Triple monitors help.
Go to solution Solved by xentric,
if you have an AMD card you mite need an active display port adapter to get all of them to work.
I got all the adapters I need but I cant seem to get all 3 of my monitors to work at once.
I have a DVI to VGA (its a VERY old monitor), HDMI to DVI, and DP to DVI.
I can have them on 2 at a time, but I cant get all 3 of them to work at once
https://linustechtips.com/topic/134043-triple-monitors-help/
CPU: 3770K | Motherboard: Asus Maximus V Formula | GPU: GTX 1080Ti SLI | Ram: 16gb Corsair Dominator Platinum 2133 | PSU: Corsair AX1200i | Storage: 2x Samsung 840 pros | Case: Corsair 650D | Cooler:  Corsair H100i with Noctus NF-F12 fans | Monitor: Asus ROG Swift PG278Q
https://linustechtips.com/topic/134043-triple-monitors-help/#findComment-1783880
Yeah... Time to wait another week for another adapter. Thanks
https://linustechtips.com/topic/134043-triple-monitors-help/#findComment-1783927
