What Cooler Should I Get for My Corsair Spec Omega RGB Case
YourBoiJoshu
Hello!
 I have a Corsair Spec Omega RGB Case. On amazon for the Corsair iCUE H150 Elite Capellix Liquid CPU Cooler there are four options, 120mm, 240mm, 280mm and 360mm. Im really bad at judging dimensions of things lol. Can anybody do some magic and do the measurements for me?
I am thinking about buying a new cooler so I would like to know!
Thanks!
Its not rocket science and Corsair lists some examples of what can fit:
Quote
Radiator Compatibility
120mm, 140mm, 240mm, 280mm, 360mm
Compatible Corsair Liquid Coolers
H55, H60, H75, H80i, H90, H100i, H105, H110i, H115i, H150i
Then you could just compare H150i dimensions to Capellix dimensions (the length difference is 1mm). But in reality, the size of cooler depends on what you are cooling.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
