I have a ROG Strix RX 6700 XT gaming OC gpu that I have vertically mounted and, well, it just looks too dark and I was wondering if anyone has seen or know of any ARGB fans or even a shroud that I could replace mine with. I know this card is fairly new so there's not much I can find online about it. Any info would be helpful. Thanks
https://linustechtips.com/topic/1340276-argb-fan-replacement/
It’s not just new it’s rare.  Hard card to even get ahold of.  There’s alway the animal method of replacing GPU fans with case fans. I’m not at all sure that would be aesthetically better though.
https://linustechtips.com/topic/1340276-argb-fan-replacement/#findComment-14750119
That card would look significantly better mounted normally so you could see the RGB on the side.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1340276-argb-fan-replacement/#findComment-14750122
Looking at that card on the Gigabyte page, I got some info for you... the ARGB is *only* along the top edge.
The fans have NO lighting...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1340276-argb-fan-replacement/#findComment-14750125
