Hi, I recently got an old Xeon X3440 which runs @3.8ghz with temps of about 84°C while doing one cb15 run. I know for sure that it can hit 4ghz easily.
For them extra fps I'd like to delid and repaste the die with normal thermal paste and not liquid metal since I'm afraid it's gonna damage anything in the long run
So I'd like to know if anyone has experience with thermal paste between the die and IHS and by how much It's gonna drop the temps.
btw my cooler is nothing special, I'm about to get a Freezer 34 to replace the old one.
https://linustechtips.com/topic/1340209-delid-experience-and-temps/
well don't do it then. when deliding you got to prepare to loose it all. shit happens.
Typically the paste under Intel IHS plates is very poor in thermal transfer.
Lynnfield chips are not soldered, so you only need to cut the glue and the plate comes off. Just have to be careful not to cut into the green board.
You may very well see a 10c drop in temps depending on where you take measurements from, generally at load is ideal.
A lot of Intel processors have been delidded in the past for poor thermals. I suggest watching a video or two before the proceedure so you have a feel for it before actually doing the delid.
Good Luck!
So far, I had a dude at my local computer shop do two delids and I am somewhat happy with the results. I replaced the IHS with copper and used liquid metal. It dropped my temps by 10~15 degrees. In my opinion, it was very worth it acoustically. However, I was not able to get a lower vcore or a better overclock out of it.
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
