now first off all i use TLauncher to run minecraft and yes i know i do piracy here you guys that hate piracy can leave now, now TLauncher says i need java with class file 60 support for running 21w19a, so i install it and remove my old class file 52 support java, and now i can't open TLauncher and it says "you need to install java 8 (class file 52 support) to run TLauncher" and so i uninstall the class file 60 support and install the class file 52 support and it works except on 21w19a, now i'm not forcing my laptop to run 21w19a, but i just wanna see the newer version of the game, any suggestion ?
https://linustechtips.com/topic/1338801-minecraft-issue/
not really. nothing you can do here with the Tlauncher. if you really want to see newer version consider actually bying the game
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1338801-minecraft-issue/#findComment-14738440
