Hi all, I've been having some issues with I'm assuming to be my RAM. This morning I ran MemTest86 for about 20 minutes on all 4 sticks with about 1500 errors. I then started to take them out one by one and after the first error I would cancel the test. All 4 sticks failed. Then I threw in some old Hyper X RAM that I had taken out a few months ago for my current fancy RGB sticks. It didn't even launch to the test. I again took them out one by one with the same result of not making it to the test. So I thought why not, put in my spare motherboard and it wouldn't even make it to the BIOS screen. So I put everything back together the way it was this morning, and now I've got no errors and its been running for about 50 minutes now.
While I was in the process of switching boards I did notice that on contacts for the CPU there was a little black patch of some foreign material, so I took a Q-Tip and cleaned that off. Could that be what was causing my issues?
Other than that I don't have any ideas of what changed to cause all my errors to go away. Give me your thoughts on what the issue might have been.
Thanks.
S y s t e m  S p e c s
CPU: i7 6800k @ 4.4Ghz | MoBo: MSI X99A Gaming Pro Carbon | RAM: 64gb G.Skill Neo RGB 3600 |
  GPU:  2x GTX 1080  | Storage: Samsung 850 EVO 500gb + WD Black 1TB |
PSU: Corsair RM1000x | Cooling: Custom Loop | Monitors: Asus ROG Swift PG278Q + BenQ RL2455HM  |
Keyboard: Razer BlackWidow ChromMouse: Razer DeathAdder Elite
Case: CaseLabs Merlin SM8 | Extra: NZXT Hu+Logitech G27, HyperX Cloud II |
| Build Log: https://linustechtips.com/main/topic/671484-project-murder |
https://linustechtips.com/topic/1338638-ram-problem-brainstorming/
47 minutes ago, Radium_Angel said:
Shorting will certainly cause issues. Dirt should never been in the CPU socket or on it.
How could that have gotten in there though, I haven't taken this computer apart in a few years at least. If that started the problems, why would it just show its face now and not before?
Critical mass I suppose, enough dust builds up that it gets into places it shouldn't have.
Or it was there all along and just moved enough to cause issues.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
