Budget (including currency): $750 USD
Country: United States
Games, programs or workloads that it will be used for: Gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I made my current PC in 2014 so it has a i5-3470, 8 gb of ddr3 and i have a 6gb gtx 960 that I put in it later on. Want to upgrade so I can play newer games at 1080p on high with at least 60fps. I think the most important things for me to upgrade would be my CPU and ram, but i don't know what i should get. Any suggestions on good upgrades for my price range.
https://linustechtips.com/topic/1338567-pc-upgrade-help/
Honestly just keep what you have for now and build something next year when everything normalizes.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1338567-pc-upgrade-help/#findComment-14736909
Here's a suggestion if you want to build everything new:
PCPartPicker Part List
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  ($212.99 @ Newegg)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler  ($69.94 @ Amazon)
Motherboard: Asus PRIME H570-PLUS ATX LGA1200 Motherboard  ($139.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($87.99 @ Amazon)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  ($59.99 @ Amazon)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($70.99 @ Newegg)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($65.48 @ Amazon)
Total: $707.37
Generated by PCPartPicker 2021-05-16 15:00 EDT-0400
I have an i7 of the same generation as your current CPU and yes, it is a bottleneck for most demanding games. Changing it to a more modern one will help greatly. If you're okay with keeping your current case / power supply / SSD or HDD, you can save a buck and take the newer i5 11600k or go Ryzen 5 5600x for example. I feel like your graphics card is fine for now. Upgrading your CPU should allow you to get by. If you want to change it eventually, maybe spend a little less right now and get something better once the prices are more acceptable.
PS: love your user name haha
https://linustechtips.com/topic/1338567-pc-upgrade-help/#findComment-14736990
