Hi guys,
I'm currently renovating my house in a fairly rural part of Scotland with only a 12Mbit broadband connection to work with and I would like to install a few cameras for security but I would rather not have data being continuously sent across my internet connection hogging valuable bandwidth.
I would like to the ability to connect remotely using a phone or tablet.
Any ideas or suggestions would be welcome.
I already have a rubust Cat6 wired network reaching all parts of the house and a home server which currently serves my files, PLEX and Lancache.
Thanks
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1337486-cctv-with-poor-broadband/
CCTV is directly hardwired (Im not an expert but I have installed my own home security CCTV system) and the only time mine uses the internet is if I want to access the live feed.  Or if I query previous recordings on the hard drive over the network.
If you plan on running with ethernet, I highly advise using PoE (power over ethernet) camera system, and have a PoE router, or PoE injectors so you dont have to run as many power lines.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Hi buddy, thanks for the info.
I wasn't sure how remote feeds works and if the NVR continuously sent data or it was an 'on-demand' thing.
Deleted - I typed this up then read it, retyped it and realized you already understand lol (and I was going down the wrong rabbit hole of info)
Unless you are on a cloud based recording service, only bandwidth as I understand it will be routed through your router to the recording box until you query the recorder over the internet
If you hook up via ethernet, these are ethernet cameras, not CCTV cameras - then yes your bandwidth is used the entire time (on your router to your recorder - thinking out loud maybe this doesnt matter since the router shouldnt be a bottleneck here nor using your INTERNET bandwidth).  (since you say NVR does that stand for Network Video Recorder?)
If you are hooking up a CCTV security system, this will use coax and power splitters that run along the coax line (from my experience) and will not affect your network unless you query the DVR.
Hi buddy, its not my internal network bandwidth I'm worried about. Its a constant stream being sent outside of my network that I don't want.
I use a Hikvision system at my work and have that connected to Hikconnect which I can connect to with a phone to view remotely. It works great but I think the Hikvision NVR send a constant stream tot the Hikconnect servers.
While I do want to be able to remotely view I would don't want a constant stream of data being sent outside my network hogging valuable internet bandwidth
Ahhhh, Im a shadetree security system/network guy.  I went CCTV for this reason (so no outside streaming to a service) and connect directly to my box connected to my home network (from phone, or PC) as long as I have the two devices linked (which I like, I have to physically have access to my box, and its QR code, to link a device to be able to query it for network viewing)
Yeh, that's kinda what I'm after. I know my upstream bandwidth sucks but if its only gonna get used when I'm connected on a phone or other remote client then I'm happy with that.
Any suggestions on a cheap or free backend for this that's compatible with any camera??
My only experience is with what came with my system - I use AVSS - its "okay" as software goes, just have to get used to waiting to cache data alot (if you switch days, etc).  Sometimes it crashes for no reason.
