Budget (including currency): 1000-2000 Euro
Country: Ireland
Games, programs or workloads that it will be used for: GTA V, Call of Duty, Fortnite, Valorant
Other details I wanted to buy my first PC soon (Next 3 months), likely prebuilt. I wanted to use it for gaming. I have a Dell Q2520D monitor (1440p 60Hz) also I have a bluetooth keyboard (Logitech K380) and a cheap mouse.
I want it to be fairly decent and run games at either 1080p or preferably 1440p. The frame rate would at minimum need to be 60Hz for most titles.
I'm not exactly sure what specs are needed for resolutions and frame rates. I was thinking about getting the Dell Aurora R12. I don't know if the base model is good enough, I think it would need more ram and the 3060ti. Is it good value for money this build.
I don't mind paying a bit of a premium but if I could get a better deal I'd go for it. I'm also open to getting a high refresh rate monitor if it fits in my budget. This would be either the Dell S272HGF (1080p-144Hz-27 inch) or the S2721DGFA (1440p-165Hz-27 inch). Is the better monitor needed?
I'm not to fused about looks, just want specs that work well. Being upgradable would be handy but want it to work for a number of years.
The specs I had priced for the R12 were:
11th Gen Intel® Core™ i5 11400F (6-Core, 12MB Cache, 2.6Ghz to 4.4GHz)
NVIDIA® GeForce RTX™ 3060 Ti 8GB GDDR6
16GB Dual Channel DDR4 XMP at 3200MHz
256GB M.2 PCIe NVMe SSD (Boot) + 1TB 7200RPM SATA 6Gb/s (Storage)
Dark Side of the Moon chassis with Low-Profile Smart Cooling CPU Heatsink and 550W Power Supply
This was 1500 euro. Is that worth it for the parts?
I get a 10% discount for Dell. Also its easy to get it delivered.
Links to the dell stuff.
https://www.dell.com/en-ie/shop/gaming-and-games/alienware-aurora/spd/alienware-aurora-r12-desktop/dawr1201?configurationid=3742a80c-f83a-4aad-9a93-493ab0ca45f8#features_section
https://www.dell.com/en-ie/shop/dell-27-curved-gaming-monitor-s2721hgf/apd/210-awyy/monitors-monitor-accessories
https://www.dell.com/en-ie/shop/dell-27-gaming-monitor-s2721dgfa/apd/210-axrq/monitors-monitor-accessories
https://linustechtips.com/topic/1336907-first-pc-need-help-for-specs/
Country: Ireland
Hmmm... in an ideal world you could get that for approximately $900, which means the list is worth double of what it was 6-7 months ago. its a decent pc, but not for the money. To make things a bit better, get the 11600k or 11600kf.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
