I recently got an IBuyPower PC (AMD Ryzen 5600x, Nvidia 3070 in a Lian Li Mesh 2) with what is supposed to be a pretty good psu, the Thermaltake Toughpower GF1 650W. The problem I'm having with it is that it is by far the loudest part of my computer, and is constantly ramping up and down in volume. From a meter away, playing Resident Evil Village, its about 44 db. The problem with swapping it is that I'm limited to the selection given on this page to pick from. Im wondering if I should try to swap for a quieter PSU, and if so, which one. I originally went with the GF1 because it was gold in the A tier list, but it is extremely loud.
https://linustechtips.com/topic/1336557-need-help-picking-quieter-psu/
That's a standard ATX power supply, so if you're comfortable swapping it yourself, you can buy pretty much any PSU you want.
650 watts should be ok, but that's lower than I would go for a 3070. I'd shoot for 750 watts to give room for those transient power spikes that the 3000 series is known for.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Nope, don't need to select it from there. If you don't mind voiding your warranty (by removing your psu and swapping it out), I'd go for an enermax revolution D.F 850. Great psu, more than enough power that'll last you a while
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
40 minutes ago, jaslion said:
Why are you limited to that page? It's just a normal psu?
Get the rm750 it's a good psu and quiet.
Good on you for picking the mesh case!
Thanks for the reply. Because its from Ibuypower, worst case scenario is I cant return only the psu for a full refund without swapping it for one on that list. Best case scenario, I can send just the psu back for a refund on that part, then just put my own in.
What're your thoughts on the Be Quiet lineup?
Too broad of a question for me to answer. They have some really good units, they make some 'meh' units, some of their older units really suck.
It's a lineup... In the current lineup, it goes from the System Power 9, which is very basic and should only really be used with low end systems, to the Dark Power Pro 12, which is one of the best PSUs on the market. Everything else is between those
Lol, yeah, I guess that was a badly worded question. Also, in the list I linked, is the Corsair RM750x the the same one as the gold corsair RMx in the A tier? I cant tell because a manufacturing year is included in the tier list for it. If so, the reviews for it say at around 650W load its only about 20 db, only huts 35 at full load, seems pretty good
Yes.  RMx is RMx.  The tier list is confusing.
