Hello, I'm looking for a headset. My picks are:
"SteelSeries Arctis 1 & HyperX Cloud Stinger Core & HyperX Cloud Stinger & Corsair HS35 & Corsair HS50."
My priority is the performance at gaming and mic quality. After that general, daily use (music etc.) matters. So what do you think, which one should I buy?
Or if you have a better option at similar price, they are welcomed.
Thanks from now.
https://linustechtips.com/topic/1336216-headset-recommendation/
Thanks from now.
Looking at "gaming" headsets doesn't mean you get the best "gaming" experience or even a good mic. The word gaming is just essentially a marketing gimmick. Anyways. If your budget is around those headsets. I would strongly recommend you stretching your budget to the MH752's because they are plainly just soo much better than those gaming headsets. Why? They are reskinned studio monitors but with a mic on it. And the mic is actually pretty good to be a headset mic.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1336216-headset-recommendation/#findComment-14719011
