CPU Power Cable?
By
IDonutsLG
in Power Supplies
in Power Supplies
Solved by WhitetailAni,
2x4-pin CPU power is the same as 8-pin if you put it together, it's just separate so you can connect it to older machines that only have a 4-pin power connector.
There is no 2x2-pin CPU power connector.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
