could go into nvidia control panel and change your Nvidia PhysX to GPU, if not already, as it could take a bit of the load away from the cpu and your gpu is good enough to hadle it, in addition to this, you could change power mode to performance, again if not done already.
Also are your drivers all up to date?
https://linustechtips.com/topic/1334681-fps-drops-and-stutters/#findComment-14707445
all of these have been already set on, and yes they are
https://linustechtips.com/topic/1334681-fps-drops-and-stutters/#findComment-14707656
