If i buy a 1 Gigabit switch would that mean that i have a 1Gigabit connection to all of the devices on the switch or does that mean I have 1Gigabit worth of bandwidth between all the devices.
Also any recommendation for cheap managed minimal 12 port Gigabit switch?
https://linustechtips.com/topic/1333688-how-does-1-gigabit-switch-work/
It means you'll have 1 gigabit to each device BUT you'll only have a max of 1Gbit shared between all devices going over the uplink to the router.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
A managed switch will normally tell you in the specs how much total bandwidth it can handle. For example my 8-port switch can switch 16Gb/s and 11.9Mpackets/s (i.e. it's able to handle full load both ways on all ports).
https://www.tp-link.com/us/business-networking/easy-smart-switch/tl-sg108e/#specifications
F@H
GPD Win 2
