Hello,
As you might have seen from the title of this video, I need some help (linked to ram)
I've recently bought two ram sticks.
One of them is faulty (An 8 gig, 2133)
You might be wondering, how do I know that? Because after all of this troubleshooting, I tried each ram stick, and voila, the 8 gig one doesn't work. And now I'm stuck to 4 gigs.
Whenever I use the 8 gig, my computer crashes/ temporarly freezes/ freezes/ freezes the application/game.
Anyways, is there a way to fix this issue? (If you've got any questions, just comment them, I'd gladly answer them)
https://linustechtips.com/topic/1333662-need-some-help-ram-fixture/
3 minutes ago, C o s m o said:
Hello,
There is no easy way to "fix" a faulty memory stick. If you bought the kit recently, you should be able to return it or get it replaced.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
Welp, recently actually means almost 30 days ago- I spent some time to find out why was it crashing.
That maybe so, but most memory kits have quite decent warranty. You should be able to request RMA.
