If the motherboard is requiring an 8-pin EPS power connector from the power supply, then that is what you need. The current power supply you have won't work with the motherboard otherwise (and there must be a very good reason for only having a 4-pin EPS connector).
You'll need a new power supply or use a different motherboard that only requires a 4-pin CPU power cable.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1333216-help-with-cpu-power/#findComment-14696964
58 minutes ago, Jellybae002 said:
I am using a dell optiplex 7010 slim case for my sleeper build, the power supply going with it only has 4 pin cpu power connector, and my motherboard has 8 pin power connector, can I plug my 4 pin into my 8 pin (I can’t get a new power supply Bc it won’t work with my case)
That isn’t true. You can run with only 4 pin power. It just depends on the current draw of the CPU you put in it.
OP. What CPU? If it’s not a monster of a chip, it may be ok. Basically any consumer CPU (so not a HEDT) will run with a 4 pin as long as your not overclocking. I wouldn’t throw a 9900k/10700k/10900k/11900k or high core count AMD in with a 4 pin. But a middle ground CPU will be fine. 4 pin can do like 150 watts, most CPU’s are 125 watt parts or less.
If you plan on having the CPU pinned like in a render machine, then I would be concerned for sure. But for gaming or general use on a middle ground CPU, likely ok.
https://linustechtips.com/topic/1333216-help-with-cpu-power/#findComment-14696985
Still some truth there...OP never told us the rest of his system that is going into this sleeper PC. If OP is using a lower wattage processor, then that is fine. What do you think would happen if they upgrade to a more powerful processor in the future, using the same power supply? Pretty ballsy if you ask me.
https://linustechtips.com/topic/1333216-help-with-cpu-power/#findComment-14697005
More of the issue is most quality PSU’s will have at least 8 pin. So it being 4 pin only may suggest it’s a lower quality/older PSU, which yes, can be an issue.
But as we go forward in time *most* things get more efficient not less efficient. And you can still build a sleeper PC with something like a 8700 or a 3600. Just because it’s a sleeper doesn’t mean it has a 5950x or 11900k overclocked in it.
My 10700k @5.1 draws about 205 watts in a very non realistic stress test. For gaming, depending on the game, it’s really not much more then 130-140 watts tops. Just to put it into perspective.
Either way, yes. We need more info to provide better insight.
https://linustechtips.com/topic/1333216-help-with-cpu-power/#findComment-14697014
