So I want to use Resizable bars as I have a 5900x / 3080. Updated both the bios and Vbios and it turns out I need to have windows installed as MBR instead of GPT.
I don't really know much relating to this difference and I was wondering if there's any big issues changing? Is it worth changing to enable it as well?
Thanks very much!
https://linustechtips.com/topic/1332816-issue-with-csm/
2 minutes ago, Oshino Shinobu said:
Are you trying to enable or disable CSM? Unless you have a specific reason to enable it, you should have it turned off and should be using GPT.
Unsure how this relates to you wanting to use resizable bar?
To enable resizeable bars it needs CSM disabled and it doesn't seem to boot into windows. People were saying I need to use MBR instead of GPT to do that?
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14693997
Again, this all seems really sus.
Secure boot works.  GPT Works.  All of these features just plain work.
If you disable secure boot, go back to Legacy, and mbr?  You'll have to wipe your drive and everything.
None of that sounds like you should have to do that for a GPU feature.
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694026
That’s what I’m thinking, it seems insanely complicated. Maybe it’s an issue with 3000 series CPUS over 5000 not letting it. Thanks for the help and I’ll avoid changing it for now
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694032
Just wondering, maybe it’s because insider build ? Perhaps it’s more restricted or something
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694040
Disabling CSM will put you in true UEFI mode, which fully supports GPT. MBR is old and shouldn't be used without a specific reason such as compatibility with legacy BIOS systems.
For what it's worth, I have resizable bar enabled, using GPT for boot and CSM's disabled without any issues.
Can you check in Windows to see if your drive is using GPT or MBR? With CSM disabled, GPT should work but MBR might not.
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694046
So…might be in MBR mode….:p
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694059
If it's using MBR, that'll be why it's not showing up when you disable CSM as it basically puts it in full UEFI mode which only natively supports GPT, which supersedes MBR.
You'd need to change it to GPT. There are some programs that can convert to GPT without dataloss, but I can't vouch for how well they work, if at all. To do it normally, you'd need to wipe the drive and reinstall Windows using GPT.
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694065
Reinstalled windows correctly, fixed the issue :P
Thanks for the help!
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14694167
  • 1 month later...
I am also having boot problems after enabling Resizable BAR with the following components:
- Motherboard X570GT Biostar with BIOS version X57AS427
- Processor AMD Ryzen 5 3600
- GPU NVIDIA RTX 3070 PCYes (Palit)
- RAM 16GB (2x8GB 2400 Mhz)
- Windows 10 Pro 64 bit
- 1 Sata SSD, 1 M.2 SSD, 1 HDD
I am enabling only Above 4G Decoding and RES BAR, all other options are BIOS default and like this the boot crashes and i am forced to reset my BIOS and keep RES BAR disabled.
https://linustechtips.com/topic/1332816-issue-with-csm/#findComment-14769293
