Ryzen USB Issues
Solved by S.Hamed23,
4 minutes ago, RobPlev said:
Sorry I should have mentioned that I have already sent the build back and awaiting refund. Just want to see what the general feeling is on buying again. Should I just wait for a permanent fix? Don't feel like risking it again
If you're in a hurry, I'd say get a replacement as it could have happened if you built it yourself.
Otherwise, you should wait until the market settles
