Fan configuration
Go to solution Solved by Pixelfie,
Front should be intake and rear should be exhaust. Other than that you need to keep the intakes and exhausts even.
3 minutes ago, Sepperl999 said:
If you mean on the top left one, it's intake. I should flip that to right
The one at the very top side, not the rear panel one. The rear panel is already exhaust, it's fine leave it. (or so it looks like, I could be wrong. Optical illusions!)
Edited by ShrimpBrime
Additional Comment:
https://linustechtips.com/topic/1332459-fan-configuration/#findComment-14691380
Sorry for answering 12 hours later. The one on the top is my psu. It propably looks like a fan
https://linustechtips.com/topic/1332459-fan-configuration/#findComment-14692356
