Built a system (3400G) in a Raijintek SILENOS PRO case. There is a wire from the front panel that's labeled "LED". I would assume it goes to the fan controller that came with the case, but if plugged in, the PC will NOT boot at all (no fans, no RGB memory, et al). Any info on this?
Thanks in advance.
https://linustechtips.com/topic/1332055-raijintek-silenos-pro-question/
Yes, it's two prong. The Power Led is labeled as such and plugged into the front panel header. This is just labeled LED. (There's also the HDD LED, plugged into the front panel header). There is an RGB button on top (near Power/Reset/et al) that's supposed to change colors or the sequence of the fans. I assumed the wire was for that button.
Could be it. You might want to trace it properly to what button. Is there a built in rgb controller it goes into?
When I plug it into the built in fan controller, that's when it won't even power on. (There's one controller on the back side of the case. The fans are plugged into that). There is a two pin connector on the top of that board that nicely matches the wire from the front panel. You'd think that would be it 🙂
