Hey guys, first time on the forums but was hoping I could maybe get some help purchasing a pre-built PC.
Budget: $3,000 (Anything lower would obviously be better)
Games: Mostly games like Call of Duty, Battlefield and so on but something that can also handle games a little more demanding a few years into the future.
Other Uses: Decent enough to stream the above-mentioned games.
Along with this, if anyone has any suggestions as to what monitor I should go with, that'd also be great.
I'm not entirely sure which location/website is best to purchase pre-built PCs from so if anyone has any suggestions/links, it would be greatly appreciated.
Once again, appreciate anyone that can help with anything.
https://linustechtips.com/topic/1332038-pre-built-pc-help/
make a custom one on Origin PC. The link I sent goes to the Neuron Builds, i chose that since you can get the 4000d airflow with that build. they use good quality parts and let you customize the build.
my signiture was cool, but its a lie now
https://linustechtips.com/topic/1332038-pre-built-pc-help/#findComment-14688219
In addition to being entertaining, this series of videos is fairly informative about the quality and experience you'll get with the different pre-built systems.
And for reference, something like this would be top of the line quality and specs:
https://maingear.com/product/vybe-stage-4-amd/
https://linustechtips.com/topic/1332038-pre-built-pc-help/#findComment-14688223
I bought one of these and love it, but the motherboard is locked and can only do bios updates with updates they put out
Ryzen 7 5800x, RTX 3070 $2499 (out of stock currently)
https://www.corsair.com/us/en/Categories/Products/Systems/CORSAIR-VENGEANCE-i7200-Series-Gaming-PC/p/CS-9050009-NA
Ryzen 5 5600x, RTX 3070 $2249 (out of stock currently)
https://www.corsair.com/us/en/Categories/Products/Systems/CORSAIR-VENGEANCE-i7200-Series-Gaming-PC/p/CS-9050011-NA
Intel I7 11700, RTX 3070 $2399 (currently in stock, 3 week shipping time however)
https://www.corsair.com/us/en/Categories/Products/Systems/CORSAIR-VENGEANCE-i7200-Series-Gaming-PC/p/CS-9050013-NA
These are pricey but are usually in stock and use basically all corsair parts outside of the motherboard and graphics card
There are likely better/cheaper options out there to be honest, their 5600x series has gone up in price since my buddy bought his at $2099
That Maingear PC looks like a really good option
https://linustechtips.com/topic/1332038-pre-built-pc-help/#findComment-14691401
