I am working on a school project and it needs to be done in scratch.... I made a program and it works as supposed, but there were some subsequent changes to the requirements for the program. Now I need to add cloning of the characters and make my own blocks. Does anyone know how to do it because I really have no clue. I searched on the internet found some sites but I just don't know how to implement it in there.
This is the game if anyone can please help..
P.s. the game is in slovene so yeah... there are some breif instructions.
https://scratch.mit.edu/projects/521840188
https://linustechtips.com/topic/1331878-need-basic-help-with-scratch/
@Mr.wut Click the "Make a block" button and give it a name, it will create a "define <name>" block and you can add instructions to it. When the <name> block is used, it will run all the instructions added to the "define <name>" block.
This is a feature to make your life easier because duplicating stuff is much simpler this way.
ಠ_ಠ
I've thrown together a simple example for you:
In the define block i described what the make sound block should do  (meow n times). Then I've used that construction multiple times. I hope this clears it up, if not then take a look at the wiki: https://en.scratch-wiki.info/wiki/My_Blocks
ಠ_ಠ
