Ryzen master problem, help!!!
Go to solution Solved by SupaKomputa,
You can also use BIOS to overclock the cpu which will be permanent.
Ryzen master is good for testing the overclock, after you restart, it will reset to normal.
You don't need youtube instructions just to install the app.
Do you plan to overclock? If not Ryzen master pretty much useless.
If it can't run, try older version of the app.
of course im trying to oc it and i will try an older version and see
yea thats why i want to use it but i know i dont want to push it to its limits so could use the bios
Well you can set RM to start the OC with windows....
What board?
Memory XMP OC?
Remove motherboard software.
Update the chipset drivers.
Check bios version and update as needed.
Then install Ryzen Master.
