A little lost here don’t know where to put this.
here goes, so my car uses the Siemens vdo CD-R 500 radio. In search of parts specifically the cdm m6 4.6 cd element as original part stopped playing cds and failed to eject them. Still trying ebay seems to only be 1 seller in Portugal for anything close to these sorts of parts however parts frequently arrive faulty go figure I know these are very old parts but just wondering if anyone else knows where to look for something like this. I have tried gumtree and shpock but no luck. Looking to spend under 50gbp preferably.
thank you
https://linustechtips.com/topic/1331668-car-audio-technical-query/
Still use CD bro?
Get a single din 7inch android stereo, it will change your life.
