I was in the middle of trying to update my bios and was currently trying to see what my bios version was. I took a photo of in on my phone then saved and exited after, without touching anything else, including the M flash. After a few minutes, it would not boot up again. I tried pbysically turning the PC off but it would not. My only choice was to turn my power outlet off. When I tried booting it up again, still, no output. Help???
https://linustechtips.com/topic/1331519-no-outputpls-help/
18 minutes ago, Stahlmann said:
Clear CMOS. (Look in your mobo manual on how to do it for your specific mobo)
I read about finding the JBAT1 on the mobo to jump it or something. I cant find. Could you guys help me out? I took the GPU out btw to make it clearer.
https://linustechtips.com/topic/1331519-no-outputpls-help/#findComment-14684012
Nvm, just found it. I apparantly do not have anything to do the CMOS since I dont have a jumper. What could I use as an alternative and how?
https://linustechtips.com/topic/1331519-no-outputpls-help/#findComment-14684025
That's the jumper. Just use a screwdriver and hold it in between the 2 pins to short them. Then hold it 10 seconds in place and your're done.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1331519-no-outputpls-help/#findComment-14684044
Thanks for the help! Worked flawlessly. Was able to update my bios to the latest ver as well. Thanks!
https://linustechtips.com/topic/1331519-no-outputpls-help/#findComment-14684135
Lol actually had to do it tonight aswell. Just updated my BIOS for resizable BAR and suddenly got no post. Cleared CMOS and my system was working again. 😅
https://linustechtips.com/topic/1331519-no-outputpls-help/#findComment-14685168
