Budget (including currency): $1200 not including monitor
Country: USA
Games, programs or workloads that it will be used for: school and games like minecraft
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I need help decreasing the price to $1200 and anything other things I should change
https://linustechtips.com/topic/1331319-first-pc-build/
drop the win10 key you can use it unactivated
since you don't have a z490 downgrade to a 10900 non k
16gb of ram is plenty for most gamers
and get a cheaper ssd if you're just gaming
although still this is soooo overkill for minecraft and school, you could easily get by with a 10400 or 11400
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1331319-first-pc-build/#findComment-14682430
2 minutes ago, Panda101 said:
Thank You for the advice
remember to quote me
here is what i would do
if you want less or more storage you could do that. also, if you plan on buying a more powerful gpu than 550w is good enough for you can change to 650w
Big nerd.
https://linustechtips.com/topic/1331319-first-pc-build/#findComment-14682453
Country: USA
Don't buy a 250 dollar M.2 SSD, I'd get a 240 GB SSD or a 480 GB SSD (M.2 or SATA, M.2 is faster) and get a 1TB or 2TB HDD, since they are about $50 USD on amazon, and the SSD would be 35-50 bucks, it would make a lot more sense.
https://linustechtips.com/topic/1331319-first-pc-build/#findComment-14682462
ok this looks good but should I upgrade anything else because I have the budget.
https://linustechtips.com/topic/1331319-first-pc-build/#findComment-14682470
If you plan on buying a 3060 ti or better I'd upgrade the PSU to same one but 650W. Other than that save up the rest for a gpu in the future
Big nerd.
https://linustechtips.com/topic/1331319-first-pc-build/#findComment-14682479
